null
Metal Antiquing
Use these products to antique or change the color of most metals, without power or heat in most cases. Just dip.
To get help choosing a solution, visit our Metal Finishing Solutions Page.
  • Alodine 120 Brush on Kit
    Gives an iridescent, golden finish on aluminum. Includes enough material to cover approx 100 square feet. Includes One quart of Deoxidine 605 One quart of Alodine 1201 Two polyethylene 250 mL breakers One nylon brush Passivates aluminum. Gives a...
    $204.59
    Add to Cart
  • Alodine 1201 - QT
    Alodine 1201 - QT
    Nonflammable, chromic acid-based, coating chemical that will produce a chrome conversion coating on aluminum and its alloys. The coating formed by Alodine® 1201™ is gold to tan in color and it becomes a part of the aluminum surface. This chrome...
    $54.44
    Add to Cart
  • Alodine 871 Touch up Pen
    Ideal for applying a conversion coating on small areas of aluminum. Also good for repairing small areas of bare aluminum. Contains Alodine 871 conversion coating in a convenient, magic marker format. Clear to light blue color Air dries.
    $168.29
    Add to Cart
  • ALUMINUM BLACKENER A385
    Aluminum Blackener A385 Ideal For Touching Up Black Anodized Parts Vary the color from a rich pewter gray to a deep black by changing dilution and immersion times. Completely colorfast through age or sunlight. Very stable under a lacquered finish...
    $27.49
    Add to Cart
  • Anodize Touch Up Kit Anodize Touch Up Kit
    Anodize Touch Up Kit Repair Scratched or Damaged Black Anodize Kit Contains: 4 oz Anodize Touch Up Liquid 4 oz Cleaning Solution 4 oz Sealing Solution Protective Gloves Cotton Swabs Instructions Our Anodize Touch Up Kit is ideal for repairing scratched...
    $32.99
    Add to Cart
  • BLACK & BROWN OXIDIZER BLACK & BROWN OXIDIZER
    Black & Brown Oxidizer Blackens silver and nickel and browns copper and brass. Mix 15% concentrate with 85% water. Use as a dip at room temperature.
    $27.49
    Add to Cart
  • Black Oxide Concentrate - 1 Gallon
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 gallon of concentrate makes 10 gallons of blackening solution...
    $226.99
    Add to Cart
  • BLACK OXIDE CONCENTRATE 1 PINT
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 pint of concentrate makes 1.25 gallons of blackening solution...
    $36.99
    Add to Cart
  • BLACK OXIDE CONCENTRATE 1 QT
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 quart of concentrate makes 2.5 gallons of blackening solution...
    $60.99
    Add to Cart
  • BLACK OXIDE CONCENTRATE 5 GAL
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 5 gallons of concentrate makes 45 gallons of blackening...
    $757.99
    Add to Cart
  • BLACK OXIDE CONCENTRATE 55 GAL
  • Black Oxide Gel Kit
    Black Oxide Gel Kit
    Easily spot blacken steel (not stainless) or iron. Simply apply the black oxide gel where you want the blackening to occur. The gel keeps the blackener in place. Leave it on the part for 1-3 minutes and rinse off. Seal with Caswell Sealer for a dry...
    $27.49
    Add to Cart
  • Black Oxide Kit - 1.25 Gal Black Oxide Kit - 1.25 Gal
    Blacken Steel Or Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in...
    $88.99
    Choose Options
